Results 1 to 3 of 3
Thread: vr commodore immobiliser bypass
    VX HSV CLUBSPORT
    Sep 2011
    perth wa
    Default vr commodore immobiliser bypass
    hi i have a vr wagon and i have to keys for it... however both remotes wont work even with new batteries..
    i dont have the key for the manual disable of the security system so i have drilled this out and found 4 wires can anyone tell me how to connect what wires up to disconnect my immobiliser?? i have tryed most combinations but nothing has worked as of yet.
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    I have seen new ecu chips made to eliminate the imobiliser when fitting a V6 into an older vehicle. But not sure on the security system.
    I have also seen it mentioned where you leave the ignition on for an hour and the imobiliser turns off.
    Also try asking in the VR - VS section.
    http://woteva.tk/
    If it ain't broke... I can break it for you
    Dangerous Dave is offline Donating Member
    VS Berlina
    Mar 2009
  1. Bypass immobiliser without key??
    By Bungle in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2012, 08:01 PM
  2. bypass stock immobiliser
    By sycvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-12-2011, 05:48 PM
  3. vt immobiliser bypass
    By nzskiboy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-06-2011, 04:28 PM
  4. How to bypass VR immobiliser in key???
    By vrcommodore2010 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-03-2010, 11:37 PM
  5. How to bypass VR immobiliser in key??
    By ryan1980 in forum Electrical Wiring / Questions
    Last Post: 21-05-2009, 08:07 AM
