Results 1 to 7 of 7
Thread: Trackcar Wiring
    VS EXECUTIVE
    Jun 2005
    Default Trackcar Wiring
    Hi guys,
    Im putting accessories and ignition on a switch and an engine start button and just want to check the wiring is correct i will not be using the key so Im hardwiring to the the wires off the ignition barrell. The engine start button has 3 terminals on it and I need to know what the third terminal is for. Is it for illumination of the engine start switch? If so do I just earth the terminal or put a illumination wire on it. Ive attached a diagram of all the wiring. Thanks
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    wiring is pretty much right, although i'd be using the switches to turn on relays. switches get broken too easy.
    with the start button, the third terminal is generally an earth, you can hook it up to the earth of the oil pressure switch, alternator etc, so it goes out when the engine is running.
    VS EXECUTIVE
    Jun 2005
    Thanks mate, i will be putting relays on just wanted to make sure the wiring was right. Thanks
    vx s pack II
    Jan 2010
    aLKIDA
    wamboin23's Avatar
    Apr 2009
    Wamboin, NSW
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by wamboin23 View Post
    Best way to test the switch is with a multimeter set to ohms
    Yeh mate Do you know the difference from ohms and continuity. You can use both.
    Trust me on that.
    Continuity means continued circuit you will get a reading of ohms in continuity mode. Not to mention it has the buzz mode so you dont have to look at the multimeter for continuity. (on some muti-meters)
    Unless you really need to know the ohms.
    Have a read of the following link mate.
    http://www.ladyada.net/library/metertut/continuity.html
    wamboin23's Avatar
    Apr 2009
    Wamboin, NSW
    and how will you know if the beeping is the closed contacts of the switch, or the illumination? it will beep all the way through to about 100-150ohms.
    and if its an LED, you won't have continuity one way anyway...
  1. Custom wiring looms to relocate under bonnet wiring to hidden areas.
    By jchar46 in forum Electrical Wiring / Questions
    Last Post: 10-05-2011, 04:52 PM
  2. Converting a VS Auto wiring loom to a manual wiring loom.
    By johnsy_vs in forum Electrical Wiring / Questions
    Last Post: 28-08-2010, 08:45 PM
  3. VT Berlina Foglight wiring/ sun visor wiring
    By GILLO in forum Electrical Wiring / Questions
    Last Post: 22-07-2010, 06:52 PM
  4. Vy amp wiring questions and wk caprice stereo wiring
    By vp_304 in forum Electrical Wiring / Questions
    Last Post: 06-07-2010, 03:05 PM
