Results 1 to 7 of 7
Thread: VZ centre console: Acc power to constant power.
    '07 VZ Acclaim wagon.
    Sep 2010
    Mulgrave, VIC.
    Default VZ centre console: Acc power to constant power.
    Quick question. Today I wired up a 12v accessory plug into the boot of the wagon. I've got a double-adapter plugged into the 12v socket in the centre console, then one wire running down the side of the console, under the rear carpet, then up the side of the boot area into the pocket where the trailer plug sits.
    Anyway, as some would know, the 12v plug in the centre console is hooked up to acc/ignition power only. I'd like to know if anyone has any idea of an easy way to convert this to constant power i.e. direct from the battery?
    Thanks,
    Luke.
    Need a part number? PM me.
    Luke.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Run a fused wire direct from the battery would be my suggestion. I would also fit a circuit breaker so it cuts power in case of a short.
    Visit my Facebook page
    Sep 2010
    Mulgrave, VIC.
    Yeah, seems like the best idea. I'm actually thinking of just leaving the current 12v plug as it is, and wiring a new separate accessory lead into the rear.
    Few metres of cable, an inline fuse and auto-reset circuit breaker, some terminals/connectors...seems easy enough
    Luke.
    Sep 2010
    Mulgrave, VIC.
    Just finished wiring it up direct to the battery. All is working well, and nothing has blown up or caught fire...yet.
    Luke.
    VY SS
    Jun 2006
    Albany
    why would you need a fuse and circuit breaker? the both do the same job so no point using the fuse
    VY S/II S Pack
    Apr 2011
    Quote Originally Posted by Luke52 View Post
    Nothing will ignite if your fuse is an appropriate size.
    Sep 2010
    Mulgrave, VIC.
    Quote Originally Posted by axemurderer101 View Post
    I was advised to use both, just in case.
    Quote Originally Posted by MAG00 View Post
    I know, the comment was made in jest
    Luke.
  1. Centre Console power supply problem , hlp pls
    By 271207 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 09-11-2010, 02:47 PM
  2. constant power ??
    By dave20089 in forum Car Audio
    Last Post: 07-12-2009, 12:56 PM
  3. Constant Power to power window switch
    By stockies in forum Electrical Wiring / Questions
    Last Post: 02-05-2009, 08:14 PM
  4. Removing Centre Console Power Switch Block
    By VTSSDUDE in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-12-2005, 10:19 PM
  5. WTB VR/VS Centre Console (Power windows)
    By Julie in forum Swap / Wanted to Buy / Trade
    Last Post: 05-09-2005, 10:06 PM
