Results 1 to 5 of 5
Thread: Handsfree Wiring
    2004 VYII S, 2005 VZ SV6
    Jan 2009
    Default Handsfree Wiring
    Does anyone know where the handsfree wiring would be located in a VZ and what color it is... Im looking for this wire as I plan to use it to power 2 headrest monitors when I get around to installing it... Thanks.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I don't know what you mean. The handsfree wire from the HU? All that does is mute the sound when the phone rings.
    The car phone loom? It is located on the left-hand side of the center console. To get to it simple open the glove box (or take it out is easier), undo the 2 screws holding the side panel on (right hand side of the glove box). Move the passengers seat to its back most position and there is a screw on that panel down beside the seat, undo that and the whole panel will come off. Once it is off you will see a white 6 pin connector there.
    Here is the wiring codes:
    Orange---------- +12 volts
    Black/green------Ground
    Yellow----------- +12 volts accessories
    Yellow/white-----Radio mute - active low
    Blue-------------Audio +
    Blue/white-------Audio -
    Copied from another forum for ease.
    Visit my Facebook page
    Jan 2009
    Yep thats what I meant to say... And yep thats exactly what im looking for so Im assuming use the yellow for power and i can also ground the monitors there with the black/green ?
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Yes and yes.
    Jan 2009
    Thanks heaps man, been a big help - kids will be pleased too
  1. VY HandsFree Replacement
    By leminz23 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-07-2011, 02:05 PM
  2. Bluetooth Handsfree in the VE
    By Robbo78 in forum VE Holden Commodore (2006 - ?)
    Last Post: 12-04-2011, 07:39 PM
  3. VT - Wiring a 3.5mm Audio jack to handsfree kit?
    By XtraSimplicity in forum Electrical Wiring / Questions
    Last Post: 15-11-2010, 06:00 PM
  4. Handsfree Car Kit Help
    By Shan84 in forum Car Audio
    Last Post: 12-10-2007, 09:42 AM
  5. VY Bluetooth handsfree kit via radio
    By mvrettas in forum Car Audio
    Last Post: 19-11-2006, 08:31 PM
