Results 1 to 4 of 4
Thread: Burnt B+ wire
    VT SS SERIES 2
    May 2008
    Default Burnt B+ wire
    Hi Guys,
    I was changing over to a new alternator last night and the B+ wire was burnt and you can see where it has been arcing out through the nut. What is the best way to fix this? Is it an auto sparky job or can I do it at home? If I can do it at home what is the best way? I'm getting conflicting ways to do it from friends, one says to run an wire from the alt to the starter and theother guy says run it straight from the alt to the positive battery terminal. I have a 2000 VTII LS1 with the 140 amp alternator. If you can help thanks in advance.
    VE
    Mar 2011
    n
    Guess what the B in "B+" stands for ... _attery
    Generally most cars are wired ALT+----------Starter+--------Batt+ because it's an easy hookup for those big cables. That's the other story.
    HIDs.....LEDs..... DRLs..... CHEV Badges..... ->
    vl
    Apr 2011
    brisbane
    probably best for a sparkie if your not confident, wouldnt want to burn/melt your car down
    VH SL/E...'09 dual cab 4X4 hilux
    Mar 2011
    roxby downs
    this happened on my VX SS but also fried the wires... i just got some new larger wire and ran that to the battery and ive never had trouble since. its not a hard job at all with the right tools ie terminals soldering iron and crimper
    If in doubt......FLOOR IT!!!
  1. burnt out fuse wire
    By vscaprice98 in forum Electrical Wiring / Questions
    Last Post: 06-01-2011, 10:33 AM
  2. Burnt out VE Ute
    By joshtaylor87 in forum VE Holden Commodore (2006 - ?)
    Last Post: 05-07-2009, 08:45 PM
  3. my ****ful car burnt out
    By skitzn in forum The Pub
    Last Post: 12-10-2008, 02:21 PM
  4. All Burnt Out
    By fabz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-04-2006, 06:14 PM
