Results 1 to 4 of 4
Thread: T56 into VN wiring
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Default T56 into VN wiring
    As the title sugests ive got a T56 thats going into a VN.
    Now im pretty sure I can work out the reverse light and lock out solnoid. But how do i get the right speed signal to the vn computer? Ive heard about using a auto speed sensor and converters etc but not sure how to do it.
    Thanks
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    does a t56 have provision to put the same speed sensor in as a t5...vn/p t5s seem to use the same speed sensor circuit as the autos...3 wires go to the sensor ...positive 12v on pink/blue and negative on a black/white and the last wire goes to the speedo head as a violet/white wire and the signal is used to show speed on the speedo face and also converted to feed from the speedo head to the ecu on a brown/yellow wire to terminal A10 of the ecm
    Its only on the vr/s that the speed sensor circuit is different autos to manuals where they have different computers.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    Nuh the T56 uses a induction sensor and the T5 uses a hal effect sensor driven by a gear.
    Not sure on the auto's tho but I think they wouldnt be different considering its the same computer in VN's. Ill have to talk to Dick from Dicks Electronics about it most likely.
    The Daily VN T5V6
    355 VN GRP A REP
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    Just pull a Dan...............................and use a GPS
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
  1. need help wiring a foglight plug into the wiring harness on a vr
    By VRCALAISS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-10-2011, 10:24 PM
  2. Custom wiring looms to relocate under bonnet wiring to hidden areas.
    By jchar46 in forum Electrical Wiring / Questions
    Last Post: 10-05-2011, 04:52 PM
  3. VT Berlina Foglight wiring/ sun visor wiring
    By GILLO in forum Electrical Wiring / Questions
    Last Post: 22-07-2010, 06:52 PM
  4. Vy amp wiring questions and wk caprice stereo wiring
    By vp_304 in forum Electrical Wiring / Questions
    Last Post: 06-07-2010, 03:05 PM
