Hi guys,
Recently my lights have been randomly coming on even when the switch is off. Can almost be 100% sure this does not happen if I leave the switch on, turn motor off, then open door (which switches off automatically), only when the switch is turned off. It has drained my battery dead flat a few times now.
I'm guessing the BCM could be playing up not cutting power to the relay?
If anyone could tell me what the problem is and/or how to fix it. Guessing will have to slightly alter the wiring between relay if it is that.
Thanks in advance
CHECK OUT MY RIDE
http://forums.justcommodores.com.au/member.php?u=62088
