Results 1 to 5 of 5
Thread: Only starts in diagnostics mode ????
    VS GTS & VT XU6
    May 2011
    Default Only starts in diagnostics mode ????
    hey guys just put a lower km motor in my car i used the computer and bcm i already had just swaped out motor and auto i now have a problem where the car will only start in diagnostics mode and when in diagnostics but i dont start it there is no fault codes showing the engine light just stays on but if i start it there is not engine light on any ideas ???
    vl
    Apr 2011
    brisbane
    VS GTS & VT XU6
    May 2011
    key head is still the same programed to the bcm and computer thats in there
    few commodores
    Feb 2011
    victoria
    check all the plugs, ground points, if in doubt dc them make sure they're clean, not corroded or bent pins causing a bad connection.... dfi module, crank sensor, oil switch & main gnd from batt to engine block? you only swapped the motor so it's possibly a bad connection somewhere.... maybe a bad sensor in the donor engine
    VS GTS & VT XU6
    May 2011
    done all the checks on every connection and wire engine ran fine in donor car and i drove it to work in diagnostics mode and back no issue everything worked fine i had a tech 2 tool pluged in and it came up with security and stuck in 3rd but again all works 100% in diagnostics go figure
  1. No Diagnostics?
    By Jamie-b in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-03-2010, 10:17 PM
  2. Diagnostics??
    By MickT in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-09-2009, 04:20 PM
  3. Diagnostics on a VT
    By Moe in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-10-2005, 07:44 PM
  4. Vn 5Lt Diagnostic Mode How To Put The ECU Into This Mode
    By scotty1000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-10-2005, 06:12 PM
  5. Fuel Consumption Normal Mode / Power mode (Overdrive)
    By peeete in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-09-2004, 10:05 AM
