Results 1 to 3 of 3
Thread: bcm
    Dec 2007
    Default bcm
    hi
    is it possible to put a mid or high series bcm into a exec by piggying back bcms patch the higher one into the wiring for the lower one and still be able to start the car with the original key/bcm but have more features like factory remote boot release
    what features does the high/lux bcm give over the low one,
    how do you get remote boot release to work with a factory remote, does mid bcm have remote boot release
    Dec 2007
    VS GTS & VT XU6
    May 2011
    you would need the complete wiring harness from the higher spec car as well its a big job and if its a VT or higher you need the ecu and bcm to be linked just having the higher level bcm doesnt give you the features everything needs to be wired
