Hi guys, i want to move the electric window switch block from the center console to the front door, the thing i want to know is if there is a way i use smaller gauge wire to run into the front door as i think all the wires will be to thick, also the central locking only locks the front doors but will unlock all four if i lock the backs manually, the car is a vn with vr statesman interior and wiring.
cheers
Only way to do it without problems is to use relays to switch the high current (like the your tin topped fuel pump relay) and have the door switches operating them
This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
Thanks for that does anyone know how many relays I would need and how to put them in
each switch has to have this circuit so if it has 4 doors then this circuit x 4
Thanks for that now I know what I need I can get started on moving the switches to the door thanks again for the advice
