Results 1 to 10 of 10
Thread: abs diagnostic wont work
    vr x cop
    Nov 2009
    Default abs diagnostic wont work
    hi guys ive bought a vr statesman the abs off light is on, bridging pins 5 and 12 wont work, i payed to have it put on a computer, it says failed to connect, they told me the prob would be in the abs unit in engine bay i changed it last night and still the abs off light is on, can someone steer me in the right direction please
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    if it won't connect to the abs using a scan tool, i'd be checking all the fuses, also there is a reverse polarity protection relay under the steering wheel for abs, try swapping this out with another one (needs to be a reverse protection relay - try wreckers).
    if this is all good, i'd be check for power, ignition and earth at the module, and/or just replace the module, which is behind the drivers side kick panel.
    the unit under the bonnet won't cause a no comms problem.
    vr x cop
    Nov 2009
    Default arhhhhh
    any pics of module in kick panel and or relay under steering wheel, abs unit in engine bay has power to everything
    wamboin23's Avatar
    Apr 2009
    Wamboin, NSW
    nope. but relay is not with other relays under there, it is on a brakcet that is attached the metal beam that the cover hinges off.
    you won't be able to miss the module if you pull the kick panel. it's in the same spot the ECU is, but other side of car.
    vr x cop
    Nov 2009
    you legend, on the metal bit with hinges mine has 3 relays there and one loose green plug? i bought the car like this so i dont no what its for?
    vr x cop
    Nov 2009
    Default abs
    ok found the module just need to find that relay! do you know the colour of the wires??
    1994 VR BT1 SS
    Oct 2011
    Tasmania
    vr x cop
    Nov 2009
    Where is this relay lol? I have changed the unit in kick panel and still no difference?
    Quote Originally Posted by wamboin23 View Post
    VP Exec
    Jun 2005
    Quote Originally Posted by xcop View Post
    That green plug may be the ABS diagnostic plug. See how you go with (checking?) the brake switch but I'll have a look (when I can) at accessing the ABS codes via that plug.
    VP Exec
    Jun 2005
    Nope. BCM diagnostic connector.
  1. Global Diagnostic System (GDS) and Multi Diagnostic Interface (MDI)
    By Jarp in forum VE Holden Commodore (2006 - ?)
    Last Post: 12-11-2010, 08:23 PM
  2. fan wont work
    By michaeldavies in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-06-2010, 08:29 PM
  3. headlights wont work
    By Dragz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-11-2007, 09:22 PM
  4. JC wont work!!!!
    By Troyziee in forum Site Feedback / Site Problems
    Last Post: 07-09-2007, 05:12 PM
  5. sub wont work
    By vpwgn in forum Car Audio
    Last Post: 11-04-2005, 09:10 PM
