Results 1 to 3 of 3
Thread: crank shaft sensor position
    VT Acclaim
    Nov 2011
    Default crank shaft sensor position
    Can someone pls tell me exactly where to find the crank shaft sensor for a VT
    VS S Pack
    Sep 2009
    if it is a V6 all the ECOTEC's are the same it is just to the left of the water pump held in by 1 bolt on the timing cover
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    Quote Originally Posted by Trikky View Post
    thats the cam shaft sensor.
    cranks shaft sensor is behind a cover behind the harmonic balncer, which is the big pulley at the bottom of the engine.
  1. crank shaft problem???????
    By vrcommodore2010 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2010, 10:09 PM
  2. Need opinion on crank Shaft
    By Rosco666 in forum Straight 6 Development And Modification
    Last Post: 30-06-2006, 05:52 AM
  3. Bent Crank Shaft
    By brey9186 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-12-2005, 10:52 PM
