Results 1 to 3 of 3
Thread: No reverse lights
    GothicKidd's Avatar
    GothicKidd is offline ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    Default No reverse lights
    I'm getting no reverse lights.
    Checked the bulbs - Fine
    Used a test light on the wiring - Nothing
    Pulled up my Auto shifter fascia and put the test light on the green wire - I have power going through there.
    Check fuse - Fine..
    I'm at a stump..
    What could it be? Also with the wiring in the boot.. If I have my brake / lights on.. And wiggle the wiring it flickers like its a loose connection..
    Is there any plugs in the loom I could look at? I've pulled my back seat out to access the wiring but cant see anything..
    Any help would be appreciated..
    GothicKidd's Ride
    I push the pedal to the floor, smoke them up and go.
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    It happened to my VS and ended up being the neutral start switch, located under the auto shifter fascia.
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    GothicKidd's Avatar
    Dec 2010
    South Australia
    EDIT:
    No idea why.. But I used a wire connector and it failed on me... fixed it now.
    thanks
    GothicKidd's Ride
  1. Vr reverse lights
    By 67wogval in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2011, 09:24 PM
  2. Reverse lights not working on reverse
    By macca_223 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-01-2010, 11:02 PM
  3. vn Calais rear lights, rear indicator, reverse lights and fuel gauge stop working
    By rustyguy085 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-11-2009, 08:25 PM
  4. No Reverse Lights
    By LewGTS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-07-2008, 02:57 PM
  5. Reverse Lights
    By ducatis in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-01-2007, 10:07 PM
