Results 1 to 4 of 4
Thread: VS keeps blowing power window and indicator/wiper fuses WTF?
    02 VX SS, 96 VS v6 wag
    Aug 2010
    Nth Brisbane
    Default VS keeps blowing power window and indicator/wiper fuses WTF?
    need some help peeps, i suck at electronics and my VS keeps blowing the p/window and indicator/wiper fuses, ive changed the p/window, drivers window and flasher relays and about 400 fuses trying to fix it but im stuck. As soon as you switch the ignition on the indicator/wiperfuse goes cause the wipers are stuck half way up the windscreen and it doesnt matter which window you put up it blows the fuse randomly WTF
    My VR is a pig
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    Power window fuse should be a circuit breaker. It still clips into the fuse holder but is self resetting. May or may not solve the problem. A common problem with a blowing indicator fuse is a broken wiper assembly causing a short
    vl
    Apr 2011
    brisbane
    hey mate, if your having problems still and can't figure it out, pm me im a mobile sparkie in brisbane that maybe able to help you out. Cheers.
    VE SV6
    Apr 2006
    Alice Springs NT
    or the hazzard switch shorting out swap that over and see mine did the same and yeah it fixed it
  1. VR wiper/indicator fuse keeps blowing- help needed
    By blakerv8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2011, 04:10 PM
  2. VX blowing indicator fuses
    By 1600dave in forum Electrical Wiring / Questions
    Last Post: 28-09-2008, 05:52 PM
  3. Blowing Wiper Fuses
    By Melchior3 in forum Electrical Wiring / Questions
    Last Post: 15-11-2006, 05:03 PM
  4. blowing fuses
    By thestash_16 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-06-2006, 12:06 AM
  5. wiper fuses blowing on vt
    By surfdog in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-05-2006, 07:01 AM
