Results 1 to 15 of 15
Thread: Combined Sub/Amp wiring
    VE SSV 60th Ann
    Oct 2010
    Default Combined Sub/Amp wiring
    Guys I need some help with a power source
    We installed the sub/amp in the boot but we used the power source of the aux 12v socket as the power for the sub. Problem is that the source is always on.
    Can somebody recommend a better source in the battery area for power for the sub
    Sent from my iPhone using Tapatalk
    vr series 2 v6
    Oct 2009
    nsw
    there should be a remote wire that you connect to your amp, and that runs to your stereo, usually a blue wire, only thin, and that tells the amp when to turn on and off and you run the 12 v amp power constant, but i suggest you run a hard wired 12 volt straight to the battery with a fuse in the line, and get according gauge wire to suit your sub and amp power, you will fry your aux 12v fuse mate
    Vs eco 3.8, extractors, 2.75" exhaust, roller rockers, cammed, bored out 20, t5 manual, rolling on king springs all way round with monroe gt shocks all way round, every door has a ding but looks can be very deceaving
    VE SSV MY10
    Jun 2006
    mobile phone plug not sure were they are if its for a ve on vr-vz they were taped back under the left side of the centre console near the glove box
    or find the radio acc wire and tap in to it there
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    VE SSV 60th Ann
    Oct 2010
    Wraith it's a fusion ported box with sub and amp. I'd have to find the number.
    Peckzz, right on. That's what I'm talking about. There is a thick red wire with big stereo type inline fuse wired to the battery. The blue wire is the problem.
    In the back of the VE is an accessory socket. This thing is constantly 'on' so you can run fridges etc in your car overnight. We attached the blue wire to the positive of this and because of my comment above, the amp stays constantly on. The green light on the amp stays on when the ignition is switched off and doors closed etc
    kcpwns's Avatar
    kcpwns is offline Kicker - Livin' Loud :)
    VY V6 Equipe
    Jan 2010
    Shepparton
    You don't connect the blue wire to a constent power source it's the remote wire and tells the amp when to turn on and off.
    Also running a sub and amp off the 12v outlet is a terrible idea I'm guessing the wiring isn't thick hopefully the fuse blows before you go melting stuff. Go buy a wiring kit from your local car audio place run a new line from your battery to amp or get them to install it for you.
    Quote Originally Posted by some_guy View Post
    This posts stupidity makes baby jesus cry.
    My Ride
    currently retrofitting projector headlights
    VE SSV 60th Ann
    Oct 2010
    Mate no offence, that's the point of the thread. Everything is wired correctly except for the blue wire and I'm looking for an alternate source than the 12v one.
    My mate installed this setup into two other VE's and both are fine. Neither had the 12v accessory socket I do. My mate wired to the same location but for some reason mine is staying live
    vr series 2 v6
    Oct 2009
    nsw
    Quote Originally Posted by kcpwns View Post
    mate read the post above yours, he re corrected his first post mate, he clearly says
    Quote Originally Posted by bonners View Post
    ok easiest way, a little dodgy but not really mate, throw a switch in that blue wire line, inbetween the amp and the 12v socket outlet, just means you will have to switch it off and on via that switch.
    usually ya just run that blue wire in behind your stereo, but with it being a new car i would not have a clue, as well as im sure you dont really wanna be pulling the stereo and dash apart, any way hope that helps mate
    kcpwns's Avatar
    VY V6 Equipe
    Jan 2010
    Shepparton
    Oops missed that guys haha my bad
    I switch could work. Can't just tap into the power wire on the factory headunit?
    My Ride
    2004 VZ SV6
    Jan 2011
    Newcastle, NSW
    I was going to suggest running the blue wire to the acc+ power going into the head unit, that way the amp will only power on when atleast acc+ is on, but not necessarily when the head unit is switched on.
    Using something like a Scotch Lok or contact connectors, you could wire it upto the factory wiring, without needing to strip or cut the wire entirely.
    VK Wagon
    Oct 2010
    geelong, VIC
    i'm not sure about new cars, i've never tried installing on them, but you need the remote wire connected (which would normally be the blue wire behind the headunit), but in this case, and guys feel free to comment, but would it work if the remote wire was connected to the ignition switch??? so it would be turning on when ignition is switched to on and then switch off when turned to off? could this work?? and with the power cable, would be best practise running it direct to the battery with an in-line fuse, reason being is the 12v socket will most likely be ran using a thin wire, not good going from a large cable to an ultra thin cable, that's when fires start like somewhen said earlier and espescially being a new car you don't want to do this half assed...
    VK Wagon
    Oct 2010
    geelong, VIC
    sorry just read the reply above mine, that's what i was thinking, running the remote wire to the acc wire that comes from the ignition...
    vr series 2 v6
    Oct 2009
    nsw
    yea i said pretty much the same as you in me first post and he re-corrected me lol
    who wants to pull there brand new ve apart???? not me lol
    kcpwns's Avatar
    VY V6 Equipe
    Jan 2010
    Shepparton
    Lol I'm useless today.
    My Ride
  15. #15
    vesv6s2
    Oct 2011
    blakeviewsa
    if its a ve you will find a plug just behind glove box to left,unclip and connect to brown pin this works on acc, thats how woolie told me to do mine works great.
  1. need help wiring a foglight plug into the wiring harness on a vr
    By VRCALAISS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-10-2011, 10:24 PM
  2. Custom wiring looms to relocate under bonnet wiring to hidden areas.
    By jchar46 in forum Electrical Wiring / Questions
    Last Post: 10-05-2011, 04:52 PM
  3. Replies: 0
    Last Post: 24-06-2008, 01:20 PM
