Hi everyone, wondering can anyone provide me with a wiring diagram for a 1996 VS Calais ABS System?
The fault code that i'm getting is no signal from the RHR Abs sensor. Because I have replaced the main body loom in the car its likely that it could be an issue between the wiring that goes from the front door to the rear of the car, abs, fuel sender etc.
Any suggestions much appreciated!
ALSO, does anyone know if - like the air bag light the ABS light has to be cleared by a scan tool? or does it just go away when the problem goes?
Thanks!!
nathans VY Calais - 'Calais 2.0' | VT Equipe | VS Calais **SOLD!**
airbag can be cleared by scantool but will come back if the problem isn't fixed i had mine come up when i swapped my steering wheel centre for a vs one so i swapped airbags an thst fixed it.
sent from tapatalk using your mothers phone.
possibilitie the abs sensor maybe rooted
now that i can see it on my phone lol try google searching the diagram in images i've found many diagrams that way
