Results 1 to 4 of 4
Thread: Air Fuel O2 Sensor Wires for S/C VX S.
    VT_sleeper's Avatar
    VT_sleeper is offline Don't G-Tech in reverse
    Black VX S II - Supercharged
    Jun 2008
    SE Suburbs of Melbourne
    Default Air Fuel O2 Sensor Wires for S/C VX S.
    Hi Guys,
    I am trying to determine if the wires for the O2 sensor at the ECU/PCM for S/C are the same as the NA ECU/PCM. E.g. I've been searching half the day and can't find a straight answer. This is for a narrowband guage (yes i know a light show.. its to fill in space until aeroforce tech arrives. but anyway..)
    D16 violet/black trace signal +, D15 violet signal -.
    signal wire for air fuel gauge
    Does anyone also have a diagram/picture of where / which loom on the ecu/pcm these are on so its easier to find?
    Thanks.
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    Why dont you just start it, let it warm up, rev it in park at about 3000rpm and probe the suspected wires with a multimeter? You'll see the voltage fluctuate between 1v and 0.
    VT_sleeper's Avatar
    Jun 2008
    Thanks, that worked.
    But I did notice some of the comments various posts have the signal earth and +ve arround the wrong way.
    For anyone else searching on a S/C wiring the following is what I used.
    D16 Blue - Black Trace signal -ve and D15 Violet signal +ve.
    Sep 2005
    No probs mate.
  1. VR BUICK COIL PACK WIRES + and - which wires???
    By H1GHROLLR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2010, 09:32 PM
  2. Fuel Sensor
    By Kirbs in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-09-2009, 10:02 PM
  3. Fuel Sensor
    By 4868rh in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-11-2008, 02:53 PM
  4. fuel sensor
    By OZI51X in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-09-2007, 02:57 PM
  5. Fuel regulator or o2 sensor first??
    By Fully in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-10-2005, 09:58 PM
