hey guys
wired the setero in the right correct way and wont turn on brand new cd player and centeral locking wont work either so i changed that fuse and still nothing so i changed it again and still nothing
can someone help is it another fuse i need to change?
thanks
There is fuse in the fuse panel below the steering column for the radio and there should be one or two fuses connected to wiring in the stereo you installed, assuming it is an after market stereo. I don't know which fuse you changed because you didn't say.
MY RIDE
that or you havent wired it correctly and your shorting something on the bcm hence no central locking = recheck wiring
