Originally Posted by
Andy
First, when you bought the bulbs, were they single filiment or double? (Does it have one wire inside it or two)?
Next. If it only has one wire, you need to buy the ones with the two wires. the base of the globe will have a double oval connection on it (It looks like ()() ) these are commenly known as Stop/Tail lights. These go in the break light socket.
Next you will need a packet of single filiment bulbs for your reversing lights. these will serve as the white lights in the rear of your car. These are commenly known as indicator lights (as they can be used in both the Blinkers AND the reversing lights.) The same light globes will service the front end of your car as well in regards to the indicators.
Please Please PLEASE don't touch the accual globe head with your bare fingers. This causes a 'Hot Spot' that will make them superheat and eventually blow prematurarly. Wear a set of cotten gloves or use a 100% cotten cloth. POLY CLOTH WILL NOT SUFFICE
If that doesn't fix the issue then a auto electrical shop might be worth a look.
