Results 1 to 11 of 11
Thread: Plug for Speed Alert VS
    Drawnnite's Avatar
    Drawnnite is offline Obviously Unsensible
    2000 Vs Ute
    Sep 2010
    Default Plug for Speed Alert VS
    ok quick question.
    pretty much im going to put a new dashplate in and it has a hole in it for a speed alert/trip computer.
    currently i just have the coin spot item.
    im just wondering is the plug for the speed alert already in the loom.
    and what does it look like?
    i had the dash off today and took a few pictures of a plug that had nothing in it and is just tied back which is just sitting there.
    could this be for the speed alert plug?
    1st is it just tied back. 2nd is up close (yes its filthy. ive been trying to clean it up a little bit)
    if not does anyone know what the back of the speed alert looks like so i can figure which plug i need?
    thanks
    how about we make the pedals out of sticky rubber and the shoes with steel spikes. at least my shins would like that
    Quote Originally Posted by Jonesy484 View Post
    yeah i wondered the same thing when i was 4 when i grabbed the chrome exhaust of my dads rx7
    Quote Originally Posted by DM 55 WA View Post
    did you think it was a milo tin?
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    That looks like the rear demister plug - not used in a ute.
    The speed alert plug is a flatish black plug and has a tube like cover on the first 200mm to protect the wires from the sharp edges.
    You will need to get a plug and wire it in.... or just replace the dash loom with a L2 loom. (thats what I would do)
    and 3 Dangerous non ABS VN's
    Drawnnite's Avatar
    2000 Vs Ute
    Sep 2010
    is it a big job to replace the dash loom with the L2 one?
    also can that be used with the dash with no Tacho?
    and thanks for the quick reply
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Drawnnite View Post
    I can change a loom over in about half an hour - but I've done a few now
    The L1 cluster will work no problem with the L2 loom as the main 3 dash plugs are the same - just have a few extra wires for the speed alert.
    Drawnnite's Avatar
    2000 Vs Ute
    Sep 2010
    thanks for that green.
    and one last question.
    it isnt this plug that i have circled in red for the trip computer is it?
    its round with 2 pins in it.
    sorry i dont have a front on view. but i dont want to repull the centre part of the dash apart (it was sitting below temp controls)
    otherwise where would be a good place to get a L2 Loom and how mucvh could i expect to pay?
    thanks
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    have you read this
    heres the plug
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    Drawnnite's Avatar
    2000 Vs Ute
    Sep 2010
    thanks for that guys.
    and thats exactly the pic i was after Markovr.
    yeah i had read that thread a few times. didnt give me any info.
    also looking at a Lv2 Loom for sale
    Patch Looms
    i know its a bit pricey. but the next question is. it the top one the one i would need?
    and dont worry ill have alook around for hoepfully a cheaper price =P
    also if i do get the L2 loom. i could just plug a L2 cluster in?
    always wanted to know my gear change revs =P
    88GreenVN's Avatar
    Jun 2006
    That loom is a L3 patch loom for the trip computer digital dash upgrade. I make the patch looms with the speed alert plugs in them along with the 4th plug - so you can run a level 1, level 2 or level 3 cluster in the car. For just an Executive L2 loom you would only pay around $30 to $50 from a wreckers.
    I also convert lots of Ute L1 clusters to L2 by melting 7 holes in the green PCB and scratching off the green coating where the nuts go. Then just fit a set of L2 gauges (you can use the original speedo from the L1 cluster as they are the same).
    Drawnnite's Avatar
    2000 Vs Ute
    Sep 2010
    so that means if i was to buy that loom. and a level 3 cluster and trip computer part for the dash (where speed alert would be)
    im right in saying i can just pull the old one out. and plug the L3 cluster/loom/trip computer in and it will work fine? (or with a little playing about)
    starting to get interested on this dash upgrading now =P
    im sure there is a proper thread on lvl 3 upgrade. so ill also go try and find it
    and use this search function most people dont seem to notice =P
    however if i only go for speed alert.
    so getting the L2 loom is best going to the wreckers?
    thanks for all your help btw guys. its definately helping
    88GreenVN's Avatar
    Jun 2006
    Yes the patch loom is about 1 hours work and calibration if you choose to do that - getting the instant fuel readings spot on. The tread is called "tripin" and can guide you through the process of making a patch loom.
    Yes wreckers are probably the bast place to get a L2 loom as they scrap most of them - not wanting to pull them out to add to the pile on the shelf LOL
    Drawnnite's Avatar
    2000 Vs Ute
    Sep 2010
    thanks for that.
    i guess there may be some more business coming your way soon =P
    and just one last thing regarding the L3 cluster.
    ive read elsewhere about having the Odo changed on them. which is apprently illegal.
    however if the Odo was going to be put up to a higher amount would they more likely to do it?
    and do you know of any places in Melbourne that it can be done?
  1. Speed Alert
    By Kirbs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-11-2009, 12:23 PM
  2. Speed alert ????
    By BUSTER1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-08-2008, 08:07 PM
  3. digital speed read out in VS with speed alert
    By vs0001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-06-2005, 06:09 AM
  4. [B]WTB: VS Speed Alert[/B]
    By monarols71 in forum Swap / Wanted to Buy / Trade
    Last Post: 12-03-2005, 06:59 PM
  5. Speed Alert
    By Braddy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-02-2005, 01:28 PM
