Results 1 to 4 of 4
Thread: L3 Loom and Cluster into VS exec series 2
    vs commodore series 2
    Nov 2009
    Boyne Island Queensland
    Default L3 Loom and Cluster into VS exec series 2
    Ok, i have read all the threads etc on L2 loom splicing etc and now realise after checking the colors that the loom i bought is actually the L3 loom. I have put the loom in and everything seems to be working so far. I have a strange problem with the dash lights. When the headlight switch is off, the dash lights are on and when i turn the switch on they go off. If i unplug the connector 4 plug it stays off. Is there a fix for this, as i am very reluctant to pull the loom out and put the old one in as it got hacked up getting it out. I also tried another BCM i have which i believe to be from a Statesman (supercharged one), but the car would not start at all.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The head light switch is wired different to the L2 as is the A/C. The L3 loom will be missing the shielded resistance wire for the lights. You will need to change every thing over to get it to work. Lights switch, BCM and so on.
    and 3 Dangerous non ABS VN's
    Nov 2009
    Looks like i will repair the old loom i pulled out and do the patch and swap them. Should be easier the second time around, you learn some good tricks that way i guess.
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Daz750 View Post
    The L2 is the easiest way to go about the L3 upgrade - and often the cheapest. If you have a speed alert L2 loom start by taping the switch block plugs together and run the L3 wires from there to just past the head light and C2 &C3 plugs - from there all the wires should line up spot on when you put the loom back in.
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  2. removing door loom vt exec
    By macksvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-10-2008, 06:58 AM
  3. cluster loom
    By VL Berlina 5speed in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2008, 09:21 AM
  4. 3 Window Cluster in VY Exec Series 1
    By breast69au in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-04-2006, 05:30 PM
  5. VN Exec wiring loom.... Help!!!!
    By stockVN in forum Electrical Wiring / Questions
    Last Post: 12-05-2005, 05:27 PM
