Results 1 to 7 of 7
Thread: VT -idler pulley&drivebelt - Computer Fault
    2000 VT Berlina 3.8l
    Dec 2011
    Picton NSW
    Cool VT -idler pulley&drivebelt - Computer Fault
    Hey there,
    My idler pulley (top) destroyed its self ( & drive belt), ignition/warning lights are all on without the key in.
    Replaced pulley&belt ($89&under a hour),reset ecu/bsm/computer 3 different ways (disconnect battery,
    remove fuses-engine-bsm-main etc)but nothing has changed, Dashlights On No Key - Ignition Loose - Key
    Remote does nothing.
    I can't get it to a Auto Elec or Mech , so any help would be greatly appreciated
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Possibly some damaged wiring in the engine bay from when the belt came off. Have a close look around in there.
    MY RIDE
    Jan 2008
    NSW
    Going on what accentstencil said. It could have damaged your ABS module, those this will throw up all kinds of lights as well as stop things from functioning properly.
    Dec 2011
    Picton NSW
    Thx guys . The belt didn't brake it just wore down & basically rubbed against the upper idler pulley until it was just rings of plastic.
    Car otherwise was fine untill wife got home ,turned engine off but ALL dash warning lights came on & stayed on (even when key was removed)
    Is it possible that the alternator was not charging due to damaged belt & the battery is low on charge? Causing the computer/key remote to not function ?
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    sounds like the ignition barrel has broken from what your describing.
    very common fault with commodores. if you search on here you should find a how to on repairing, or call a mobile auto locksmith.
    i'd say is just a coincidence.
    Dec 2011
    Picton NSW
    Dec 2011
    Picton NSW
    You champion, had time & patients to pull the covers off today,
    And once I got the ignition switch off the barrel housing -
    Found that the END(spine) off the ignition barrel HAD snapped
    and that was why the ignition(&lights) were still on.
    Pick up new barrel&keys from Auto Shop tomorrow on way home from work, will install
    in the arvo -& let ya know how it goes.
    Thanks for the tip mate :-)
  1. Idler Pulley Q
    By raovq in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-06-2010, 06:06 PM
  2. VT - DriveBelt Pulley not Turning ??
    By Rhin0o8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-06-2010, 05:20 PM
  3. Pulley idler changes?
    By Aus78Formula in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2008, 06:52 PM
  4. vt Idler Pulley
    By sheapard in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-10-2007, 06:07 PM
  5. Idler Pulley
    By AirStrike in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-01-2006, 09:29 PM
