Results 1 to 9 of 9
Thread: main power fuse melted and the main power wire melted in vr commodore
    GENESIS BLUE VR COMMODORE
    May 2011
    Gippsland, Victoria, Australia
    Default main power fuse melted and the main power wire melted in vr commodore
    hey guys
    i just had a issue with the vr once again
    the main POWER lead off the wiring loom to the main fuse for the car is melted the wire and the main 60amp power fuse is melted also what would be the cause of this issue
    cheers
    This Isnt A Site To Talk About Your Relentionship Problems Its A Car Forum
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    make sure all ya earths are clean and the alternator cable isnt melted at the alternator, id replace the cable going from alternator to the battery and battery to teh main fuse and any other wires that seem melted etc, and cheak all the wireing loom over for bad connections and shorts to chassis (with the positve cable)
    also make sure started motor cable aint melted, follow it down from battery to starter moter if suspect replace
    dont no if this will help but hope it does mate
    doctor who is offline Banned
    ssv redline
    Dec 2011
    Esperance
    ssv redline
    Dec 2011
    Esperance
    vl
    Apr 2011
    brisbane
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    The only explanation is a short has caused this, Beit from a wire has broken free, or did u have an issue with ur stereo n central locking? U may have shorted a few wires when doin the install?
    U'll need to check over ur looms, and as a few said check the back of the alt.
    May 2011
    well i been having this issue with no power and i thought it was the battery so i charge the battery reconnect the plugs and it would work never thought it was this wire till the other night when it happened and i put my hand in in the dark and burnt my hand due to the wire being so hot so i got home and i put a light on it and its the main power wire from the loom been complety inhalf and the main power fuse melted in and i couldnt get it out
    now to the setero i installed the setero but now seen i have a blown fuse meaning setero is wired wrong meaning that could have a issue with that lead whats completly fried,
    now i put the multi meter on the wire of the loom and im getting 12volts thru the car from the power lead without the battery connected is that normal?
    and yes i think im going to check the alternator
    and im rhinking of going to the wrecker and the eletronic joint and getting a new plug and fusebox and im going to new plug it and re wire it all but do i do that yet or will i frie again?
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Start by replacing the parts that r cooked, new fuses and relays if affected. Remove ur stereo, and any wires u touched with the install and see if it all returns to normal.
    May 2011
    i changed the setero fuse going to re wire the setero and going to re wire the fuse box and i see how that goes if it happens again ill be stumped as ive checked the whole loom in the engine bay no cuts or wires touching anything that would short to cause this issue so im stumped how its happened
  1. VS Commodore. Rear Window Heater Fuse Melted, Now No Indicators.
    By Franga in forum Electrical Wiring / Questions
    Last Post: 19-07-2010, 10:02 AM
  2. VK Fuse box melted
    By vknut in forum Electrical Wiring / Questions
    Last Post: 10-11-2007, 03:13 PM
  3. melted fuse box
    By VKnVLCalais in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-11-2005, 12:16 AM
  4. Melted Fuse
    By midnight.outlaw in forum Electrical Wiring / Questions
    Last Post: 31-03-2004, 05:12 AM
