Results 1 to 2 of 2
Thread: aircon compressor not engageing VT
    2010 Yamaha R1 & 2000 VT SS
    May 2008
    Toowoomba
    Default aircon compressor not engageing VT
    so did an engine swap and just putting the aircon back in. everything is hooked back up and gassed up and everything works fine except the compressor clutch wont engage for the aircon to work. checked the relay and found there was no signal coming from the pcm so tested the wire between the pcm and relay and thats fine. hooked up a tech tool and can manually engage the compressor and the aircon works, so the signal between the bcm and pcm then to the relay is all fine. it just wont do it when i push the a/c button on the dash. the car did receive a tune by power torque after the engine swap before there was any aircon parts put back in. any ideas?
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Pressure sensor on the condensor plugged in?
    Quote Originally Posted by moggy
    That was pretty gentle and loving. Assault my arse.
  1. Vp Aircon compressor problems
    By Huntington in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-06-2010, 02:21 AM
  2. Installing VT Aircon Compressor
    By Sam_Vt5spd in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-07-2009, 03:22 PM
  3. WTB** VT VX Aircon Compressor
    By wwilde in forum Swap / Wanted to Buy / Trade
    Last Post: 14-02-2008, 09:45 PM
  4. F/S in SA, VN V6 aircon compressor
    By churnit in forum Parts And Other Items For Sale
    Last Post: 08-03-2007, 11:36 AM
