Just thought I'd give a little plug for these things because I just got mine in the mail and they are an awesome piece of gear.
There's nothing I don't like about this boxfrom how it looks in the boot, to how comprehensive the collection of ancillary bits and pieces is. There's even two options provided for the lid seal, each with a set of slightly different sized clips to suit.
The only place I could find that stocks one (granted I didn't look that hard) was Rocket Industries. I bought the black one.
They come with way more included stuff than you see in those pictures.
Anyway just thought I'd throw this up, if you're not sure it'll be worth the extra cost for one of these over a shitty supercheap special, it is.
Sam
WTB: mulberry VN interior parts
whatever your standard sized VN-VS-VZ battery is, ... that size. And probably a bit bigger, I'm sure I've seen yellow tops etc in them before and I think they're bigger than normal.???
Pretty similar physical size, they fit easy in commodores where a normal battery would (D34 yellowtop)
I just got mine in the post today from vpw. great kit. Very happy with the quality and the price. I'm also getting the moroso remote battery terminals.
Daniel
Sent from my iPhone using Tapatalk
Daniel
VH SL/E Blue on Silver
304 Conversion | Custom Headers | Trans-Go Shift Kit | 2800rpm stall | VL Turbo Diff | VL Turbo rear brakes | VT Twin Piston Front Calipers | VT Brake Booster | Slotted Discs F&R | Nolathane bushes.
Interested in suggestions on what to use to chock up one side of the box in the boot (necessary because of the uneven metalwork on the driver's side of the VN boot floor)
Any reason a couple of bits of stacked ply (under the carpet) wouldn't work?
Spray expanding foam filler outside car, cut piece to size, paint black, use that?
I don't know![]()
Well I hit another hiccup which has made me solve this problem a different way.
The only spot in the boot where I like it requires one of the mount points to drill down through a chassis rail. FAIL.
Thankfully that's on the low side so I'm going to make a bracket up out of a spare ecu cover (lol) so I can mount the box to that, then mount that to either side of the chassis rail.
Am I worried over nothing?
Daniel
