Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By millsman
Thread: VZ - All dial gauges stuck
    VZ Exec Wagon
    Dec 2005
    Default VZ - All dial gauges stuck
    I have a 2005 VZ Commodore wagon with 140K on the clock. All 4 of the needle/dial gauges have become stuck at some point whilst I was driving yesterday. The temp is at 1/3, the taco at 1,500 rpm, the speedo at 80km/h and the fuel at 3/4.
    Here's what I've discovered so far:
    - the digital speedo works fine
    - disconnecting the battery and reconnecting hasn't fixed it
    Does anyone have any ideas on what the possible common fault is that has caused all 4 needle/dial gauges to fail at once, or how I might go about fixing it?
    I'd appreciate any help.
    Thanks, Andrew
    VR Statesman, WK Statesman
    Aug 2006
    I had a similar situation with my 2003 Statesman. The needles would all either stick where they were, or completely max out. I would turn off the ignition and they would stay there, but reset to zero when I started the car next. It would happen on a regular basis.
    I fixed the problem by simply pulling the dash out, disconnecting the wiring loom, and plugging it back in again. Never had the problem again.
    VZ Exec Wagon
    Dec 2005
    @statey1975: thanks for the suggestion, but disconnecting the cluster didn't resolve the issue.
    I did end up with a solution. The end result is that the instrument cluster needs to be replaced.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by millsman View Post
    Sounds like it was getting stuck in Diag mode.
    and 3 Dangerous non ABS VN's
    Aug 2006
    Ouch....bet that was a bit pricey....
  1. vt VDO dash dial
    By 98vtberinla in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-08-2010, 11:33 AM
  2. Wade Cam Dial in??
    By Bz Kn33z in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-09-2008, 03:16 AM
  3. vl dial kits
    By mantisvk in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-07-2008, 07:01 PM
  4. gauges in vn always get stuck!
    By mrVT in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-02-2006, 04:07 PM
  5. style dial
    By commnz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-05-2005, 12:07 AM
Tags for this Thread
