Results 1 to 5 of 5
Thread: vx calais wiring questions (indicators/stereo)
    S/C VX Calais
    Apr 2010
    canberra
    Default vx calais wiring questions (indicators/stereo)
    i have a 2001 vx calais and my indicators often stuff up, they blink really fast as if a bulb was blown but they are all fine. it only does it every so often.. ive changed the fuse and the flasher relay and its still the same. hazards work so ive come to the conclusion it must be the indicator stalk?
    can anyone confirm that or help me at all?
    i was also wondering if anyone knows if its possible to wire up the stock subs to a aftermarket head deck?
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    does it only do the quick clicking when the indicators aren't been used? if yes, it will be the stalk for sure.
    as for the subs, i'm not 100% sure, but I guess there would not be any problems. I'd wire them using an aftermarket amp, and RCA's from the headunit.
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    With my WH Statesman, when I had the aftermarket head unit installed, the stock subs stopped working. I think you can run them off the head unit (not through an amp), but you would have to run extra wiring. It's not worth it IMO.
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    S/C VX Calais
    Apr 2010
    canberra
    Quote Originally Posted by wamboin23 View Post
    it only does the quick clicking when i try use the indicators but it only does it sometimes.
    yeah thats what i thought.. i was hoping i could just change a few wires around so itll be easy to change back to the standard head deck if i wanted to
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    If you did install the stock head unit again, the stock subs will start working again, it's just something with the aftermarket head units. I kept asking if I could get mine working but they said it's a lot of work, and because I have an aftermarket sub, there would be no point getting the stock subs to work, because the aftermarket sub would be over powering the stock subs so you wouldn't be able to tell that they were even working.
  1. VXII Calais stereo wiring
    By Fletch_QLD in forum Car Audio
    Last Post: 14-05-2011, 10:39 PM
  2. VX Calais Maestro stereo wiring diagram
    By Perkulees in forum Car Audio
    Last Post: 17-01-2011, 05:36 PM
  3. Vy amp wiring questions and wk caprice stereo wiring
    By vp_304 in forum Electrical Wiring / Questions
    Last Post: 06-07-2010, 03:05 PM
  4. Wiring Alarm to Number plates and indicators??
    By ICUBYE in forum Electrical Wiring / Questions
    Last Post: 21-07-2006, 08:32 PM
  5. Vs Ute Stereo Questions
    By Troy711 in forum Car Audio
    Last Post: 15-01-2004, 12:01 AM
