Hi, my VR is doing strange things with the fog lights.
if i have my headlights on and i switch the foggies on.. the headlights go out and revert to parkers?
Foggies are meant to be able to work both with parkers and headlights right?
Whats goin on here?????
Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
To answer ur question, no.
That's the way they are set from factory. U dont want headlights on when using fog lights, u want the light low as possible, under the fog.
I know u can place a wire between 2 relay pins which allows the foggies on at the same time as headlights. The coppers love this mod also!
I can but I don't have my pc with the doc on which pins on the relays. Not much use ATM, I'll post it up tomorrow if someone doesn't get in before me![]()
Basically you jumper a wire across terminal 30 and 87a on your fog lamp relay and they will both stay on when you want them to
This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
Couldn't have, if vr requirements were to switch off the headlights for fog when turning on the foglights, then the vs would be the same, ADR rules would never change that rule. Both vr n vs they are classed as fog lights not driving lights.
Dunno what ADRs have to do with it, but basically it is known you get a better vision in fog, with foglights on and headlights off. The VR headlights turn straight off when foglights are turned on, updated on the VS so you can choose to have the headlights on or off for safety reasons.
