Results 1 to 4 of 4
Thread: VP V6 fan control
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Default VP V6 fan control
    Hi all,
    In a VP V6 how is the ECU programmed to turn the fan on, ive got a small problem with mine not wanting to turn the fan on while your moving and in slow moving traffic the temp gradually rises and the fan wont turn itself on unless you stop. Then instantly it switches on when you stop.
    Sitting still it works fine, cuts in a little above half then out again above a quarter on the gauge. Car doesnt overheat or anything, when the fan doesnt turn on i just flick the overide switch but every now and then i forget to look at the gauge and its getting a little hot.
    Any Ideas?
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    There's a speed setting that the fan will cut out at in the memcal. I don't recall what it is at the moment.
    Illegitimi Non Carborundum
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Quote Originally Posted by FXST01 View Post
    Ok cool, maybe my conversion speed sensor is telling the ECM its going faster then it is?
    Speeds greater then about 50km/h its sweet, but i would still think that it might kick it in before it stops? even if youre only crawling along.
    Had fiddle with the ray gun today, seems to kick in about 90c (which is half on the gauge) then out again about 85c. sounds right?
    Ghost's Avatar
    Ghost is offline Donating Member
    Vr Commodore Executive 1993
    Sep 2011
    Adelong New South Wales
    In my vr the fan only kicks in when it shows half way when it cuts in when you are stopped is because it has been setup by someone that your brake light switch is acting as another override switch when the brake lights come on the fan activates
  1. VR V6 93 Acclaim heater control / climate control switch
    By tom slick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-04-2011, 02:26 AM
  2. [VR-VS] How to change Heater Control globes (NON climate control)
    By Fonzie in forum Holden Commodore How-To's
    Last Post: 03-08-2009, 11:28 PM
  3. Climate Control/Standard Heater A/C Control
    By swift85 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-03-2009, 07:44 PM
  4. trac control button and heater control lights!
    By mrVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-04-2008, 09:07 PM
