Results 1 to 5 of 5
Thread: vn wont start .electrical short
    vx
    May 2009
    Default vn wont start .electrical short
    Hi, had a flat battery in the vn and used another battery and to start it and was changing them over while car was running and I got a spark from around battery area,car cut out then havent been able to start it since,it does turn over and will occasionally lightly fire and then get a small backfire through the airbox but still wont fire.also i have noticed a wire off the negative battery terminal with a computer protector small box,just wondering if I have knocked this off also ,so was
    wondering where the other side of the wire connects to.
    thanks dave
    Ghost's Avatar
    Ghost is offline Donating Member
    Vr Commodore Executive 1993
    Sep 2011
    Adelong New South Wales
    Ok well to start off switching batteries while the car is running is plain stupid the things your going to have checked and maybe replaced is as follows : the starter motor the ecu the coil pack for v6 distributor and cool v8 and the alternator
    Ghost's Avatar
    Sep 2011
    VQ Caprice
    Jan 2012
    Clunes NSW
    Quote Originally Posted by heathsydm View Post
    Unfortunately heathsydm is right, that was a stupid thing to do, you could do it in the old days before the cars had computers but now you cant, Alternators are irregular in the amount of Volts and Amps they put out and the battery even if it is dead flat will act to regulate this voltage and amperage, once you take the battery out while it is running the alternator will surge in voltage and amperage to compensate for the lack of a battery often killing the computer.
    However all is not lost, try checking all the fusible links first, there is a little black cover with 5 main fuses in it, down low between the battery and the the main relay panel, take of the little long black cover and check all five main fuses, then check all your fuses under the dash especially the ecu fuses, if all of these are ok then check the ecu relay under the big black cover between the shock tower and the battery, switch out the ecu relay and with another and test the engine, if still no joy I would imagine you have fried the ECU, I would borrow one from one of your friends first and put it in to see if it will run, if so take your old ecu to the wreckers so they can match the numbers and get yourself another one. Hope this helps - Jon.
    Ghost's Avatar
    Sep 2011
    Of coarse I'm right I've been working on cars for 10 years lol but anyway hope we have helped
  1. Where is the electrical short?
    By boohsv in forum Electrical Wiring / Questions
    Last Post: 23-09-2010, 04:23 PM
  2. Burning Electrical Smell..now vr wont start
    By wdrury in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-07-2010, 11:10 PM
  3. my friends vl wont start i think its electrical problem help me guys
    By vh2nv in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-03-2010, 07:41 PM
  4. Help please vr statesman short out now wont start
    By H1GHROLLR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-02-2010, 06:33 PM
  5. electrical short?
    By yobbo in forum Electrical Wiring / Questions
    Last Post: 26-06-2006, 12:19 AM
