Results 1 to 13 of 13
Thread: Speedo not working after dash conversion
    Toyota Lexcen (VP Commodore) wagon
    Dec 2010
    Australia
    Default Speedo not working after dash conversion
    Hey all,
    I recently did a dash conversion in my vp to that of a vr...problem is that now my speedo doesn't work along with the fuel and temp gauges.
    The trip meter and odometer have also failed.
    I'm using the original wiring loom as well as the original instrument cluster so there shouldn't be any problems there and the plugs that go into the back of the cluster weren't cut or modified in any way. The tacho works though which is a relief 'cause I can guess my speed off that.
    I can't see any noticeable breaks in the circuitry behind the cluster and the little plug that goes into the speedo is connected.
    So my question is: has anyone done the conversion before, have you come across the same problem or one like it and if so, how did you fix it?
    Old cars, are they really worth all the problems and screw ups?.....yep!
    Ghost's Avatar
    Ghost is offline Donating Member
    Vr Commodore Executive 1993
    Sep 2011
    Adelong New South Wales
    How can you be doing a conversion and still use the original cluster?
    If you put a vr cluster in its going to need re wiring the vn/vp clusters can be swapped but not vr/vp as the wiring was changed around you can either waste time with a sparky and have it all rewirred or you can get the right cluster
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Check that your plugs are in order and up the correct way. If you have the plugs upside down things fail.
    and 3 Dangerous non ABS VN's
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by heathsydm View Post
    I think all the OP has done is change the dash pad not the cluster.
    Ghost's Avatar
    Sep 2011
    Dec 2010
    Australia
    Yeah I just changed the dash pad and kept the original cluster as they're the same right the way through to vs... except for some that don't have a tacho. Mine does, however, and so I was able to keep it.
    88GreenVN, when I was putting the plugs back into their places in the dash, they just sort of fitted in naturally one way so I can only assume that they were the right way up. I'll have a look tomorrow arvo though, just to be sure. Thanks for the advice.
    heathysydm, not everything isn't working, the tacho works fine. And having done all my own wiring of lights and radios along with some of my brother's, and had them working, I know enough about electrics to do my connections properly so I doubt it's a problem with my wiring technique. However, I have been wrong in the past
    88GreenVN's Avatar
    Jun 2006
    Orange on the left side, blue middle and orange on the out side.
    Ghost's Avatar
    Sep 2011
    Yeah but only a tacho isn't much good but something isn't adding up it might be the ecu try resetting that as well
    88GreenVN's Avatar
    Jun 2006
    The clusters altho have heaps of wires can go belly up on just 1 plug being around the wrong way.
    Dec 2010
    Australia
    Yeah I have the colours in the right places but I'll fiddle with the plugs tomorrow and see what happens. Thanks for the help guys, I'll let you know.
    Ghost's Avatar
    Sep 2011
    Good luck but my advice for the time being use a gps as a speedo coz they are 99% accurate and police will find any excuse to pick on ya
    Dec 2010
    Australia
    All good now, I had the plug on the right upside down. Now everything works as it should. Thanks guys, your help was much appreciated.
    Ghost's Avatar
    Sep 2011
    That's good
  1. speedo not working after manual conversion on vr
    By kevspec in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-12-2011, 09:25 PM
  2. changed dash lights in vr, now speedo not working :S
    By sherwindy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-10-2011, 07:40 PM
  3. vn v8 conversion into v6 vs, speedo not working
    By Patto68 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-11-2010, 09:06 PM
  4. Vr level 3 dash speedo not working after upgrade.
    By dk4400 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-05-2010, 12:00 PM
  5. Level 3 dash speedo not working after upgrade
    Last Post: 22-05-2010, 06:23 PM
Tags for this Thread
