Results 1 to 16 of 16
Thread: Twin battery setup
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    Default Twin battery setup
    Hey all
    Just wondering what sort of wiring I should use to link the 2 batteries.. the plan is to have a D34 yellowtop in the rear, and a standard in the front (possibly a D34 in the front one day depending on the bank..)..
    It will have a healthy audio system (couple of amps) wired onto the rear battery, plus the option of a fridge or something one day if I take it camping..
    I currently have a roll of 4 gauge sitting here, but not sure if it is enough for the load from the alternator (keeping it charged/transferring charge from one to the other)..
    If anyone can shed some light onto it it would be great (as to if I should just use the 4 gauge or upgrade to some bigger stuff)
    VKC
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    I wouldn't be using 4 guage. What vehicle will you be putting it in?
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    Gotta love paint :P
    Basically, like this (except front battery is connected to the ground. haha. Musta saved before that. lol)
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    How often will you be running the fridge? Just a single upgraded battery should be ok if your not camping for an entire weekend or something.
    Jonah 101's Avatar
    Jonah 101 is offline I love photoshoppin
    vs executive Manual
    Jan 2012
    Tauranga
    Question, Do you have to run the batteries connected to each other? could you not have a wire running off the alternator to the rear battery to charge it and save the rear battery just for sounds and fridge?
    My ride-VS commo, Just finishing the manual conversion. Working out those annoying bits!
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Quote Originally Posted by Jonah 101 View Post
    With most proper dual battery set-ups the second battery shares the charge with the first.
    showbags's Avatar
    showbags is offline Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
    Why don't you use a 4WD type dual battery kit, them you get everything you need and you know it'll work. Projector & Red Arc both make good ones.
    Jonah 101's Avatar
    vs executive Manual
    Jan 2012
    Tauranga
    Sweet as, was just an idea I thought up a while ago and wondered if it would work.
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    Quote Originally Posted by wraith View Post
    Fridge will be very rare, it will be an if, not a when.. Id just like to have the extra power there if I need it, or even if I want to run the stereo or something when im camping.. only problem I see with the projecta kit is I have to have the ignition on to have the stereo on, which will link the 2 up..
    That would still connect the front to rear, as the alternator goes to the front one..
    Quote Originally Posted by showbags View Post
    You reckon just a DBC150? http://www.projecta.com.au/Images/PD...Management.pdf
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    I would just try a better battery first and go from there. If it doesn't work out then by all means go dual battery. It can be a pain running cables etc for dual batteries.
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    I was going to be running the wiring anyway (to link the amps to the battery), and was considering getting a D34 as I still work for optima, so I was thinking put that in the boot, link the 2 together and keep the front until it dies, then go from there, whether I go for another d34 or what.
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Well in that case pick up a Redarc dual battery setup. Run at minimum 2 guage. Hardest part will be running the wire to the back. Don't think there's a hole big enough through the firewall.
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    Cheers.. So 4 will be too much voltage drop?
    What model would you recommend?
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    That and the potential current draw. It's always better to go larger. I have seen 4 guage setups but I am more of the school of over do it rather then under when it comes to cables.
    Dual Battery Systems and Alternator charging
    See if that link helps.
  15. #15
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    Thanks
    Ill have a read through it
  16. #16
    VY SS
    Jun 2006
    Albany
    At my work we use 2gauge on all dual battery systems under the bonnet with the redarc dual battery relay, what car is this going in? if its an auto you could easily run a pos and neg cable through the clutch grommet then you just have to get it under the door sills all the way to the back. And make sure you have a large circuit breaker or fuse on both batteries.
  1. [QLD] WTB. LS1 twin turbo setup or manifold
    By OFF T4P in forum Swap / Wanted to Buy / Trade
    Last Post: 23-07-2011, 04:55 PM
  2. [LS1] Twin turbo setup on LS1, what will i need?
    By Kingston_99 in forum LSx Development and Modification
    Last Post: 11-09-2010, 08:07 PM
  3. twin turbo setup on ls1?
    By cpbait in forum LSx Development and Modification
    Last Post: 22-08-2010, 03:14 PM
  4. Twin exhaust setup
    By DANNY8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-09-2008, 11:30 PM
  5. twin throttle body setup
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-03-2006, 07:13 PM
