i dont know if this is a wiring problem but im gusssing it could be
my vt antenna has stopped going down and up by its self is it something to do with the wires or is it just stuffed?
it happened to me and all it was.. my Radio/Antenna Fuse was blown it is a mini 15A one, it is located right under your steering wheel behind that interior plastic thing that folds down directly under the head lights switch
so check that first
If you can still hear the motor working then its not a fuse. All it should be is the plastic belt that makes the antena move up and down it has snapped you just need to replace it. If you cant hear the motor engage then check fuses or the the motor it self is stuffed.
ok thanks the motor dosnt sound so ill check the fuse
