Results 1 to 11 of 11
Thread: Alternator whine through stereo - 304
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Default Alternator whine through stereo - 304
    Car is a VN 304, the noise is much more noticeable when I turn on my headlights. Comes through the amped front speakers.
    Also, because my fuel pump is a fairly noisy Walbro GSS341, I can hear it running if the ski port to the boot is open, and I noticed tonight that at idle the pump sound changes - its RPM seems to drop a little. I've been having trouble chasing a ping as well, which to me screams low fuel pressure (greenfoam tune so that's solid), so I'm starting to wonder if these things all point to a common fault?
    Alternator failing, is that a possibility?
    You guys no doubt know a lot more about these things than I do so I thought I'd ask!!
    Sam
    WTB: mulberry VN interior parts
    showbags's Avatar
    showbags is offline Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Terminals are pretty new, I don't think they are the issue.
    Earth cables.. well I earthed the absolute crap out of the amp, and the block has an extra earth on top of the one it had from factory.. so I'm not sure what further to do there.
    Commodore SS MY11 (Dad's) Subaru Liberty 95 (Mine)
    Jan 2012
    NSW
    Could be worth looking for a more powerful alt at least you know that your fuel pump has got plenty of volts going to it at all times.
    Jan 2012
    NSW
    Pings can be caused by timing aswell.
    I believe if it's to advanced it will ping I could be wrong though
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Check what the battery volts is at idle and flight, should be about 14v and can be a little lower at idle but still above 12v, chances are the volts are dropping at idle so your pump slows a little which is normal. Could cause a ping if the volts drop critically low but you would have more problems if that was the case.
    When you hit the lights your alternator starts working harder so your volts will drop a little and you will hear it whine more, when they whine through the stereo its because one of the little electric dampeners anti-static things (there real name escapes me, looks like a little capacitor with one wire going to it usually) is playing up and you get a buzz. Cheap and easy fix.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Quote Originally Posted by HoldenCommodoreVE View Post
    Yep, but what I was more saying is that the timing is spot on - greenfoam tunes have always been excellent in that regard - so I must start looking at other possibilities
    Quote Originally Posted by VK SL 3800 View Post
    The capacitor thingo - is that on the amp, alternator, where?
    I'll check the volts running @ idle, and running @ ~2000rpm, and see what it looks like (terminals have built in V- meter --- easy job!)
    Blown VS Calais !!
    Jan 2005
    Kalgoorlie WA
    Ten characters
    Right click save as . .
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Quote Originally Posted by savage1987 View Post
    Back of the alternator, im not sure but the early girls have them on the coil as well so just check there too.
    drewVHSS's Avatar
    drewVHSS is offline Donating Member
    '83 VH SS, '79 Malachite Green VB SL '91 VQ Stato
    Apr 2010
    Gosford Central Coast
    Check the "Condensor" on the back of the alternator to make sure the thin wire hasn't gone brittle and broken off.
    There should also be another noise suppressing condensor on your ignition coil.
    If these are faulty you would experience your electrical noise issues.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    I hate that Holden decided to put the coil there..... all the wiring I can see seems OK.. but that's not much of it. Same on the alternator - the main power wire is secure, and the injector-style plug is secure as well. Not sure if there's meant to be anything else attached but there doesn't seem to be.
  1. Vr Commodore alternator whine
    By aussiebluVR in forum Car Audio
    Last Post: 09-06-2011, 07:44 PM
  2. Alternator whine
    By Crossy_014 in forum Car Audio
    Last Post: 01-07-2009, 10:54 PM
  3. Alternator Whine (rear speakers only)
    By nickwontlose in forum Car Audio
    Last Post: 16-05-2009, 05:13 PM
  4. alternator whine in stereo
    By impulsesv6 in forum Car Audio
    Last Post: 03-02-2007, 12:36 PM
  5. Alternator Whine
    By cycom563 in forum Car Audio
    Last Post: 01-02-2005, 09:58 PM
