hello i am at my end with car im about to try another ecu the problem i have is that the enging is getting way to much fuel the oil in the sump is just turning petrol i cauld run my 2 stroke on it lol i have changed map sensor cauld it be my regulator or is it my ecu PLEASE HELP before i set fire to my baby
if your getting that much fuel you most likely have a stuffed injector.
heres my ride, i know its not much but its mine
http://forums.justcommodores.com.au/...-ss-crewy.html
and heres my new project
http://forums.justcommodores.com.au/...ml#post1104629
Have you tried to pull a code and see what that says?
