Results 1 to 9 of 9
Thread: Parker light question
    Vx Clubsport R8
    Sep 2011
    Townsville QLD
    Default Parker light question
    Gday does anyone know if there is a way so that the parker bulbs are off while on low beam?? In a vx it that makes it easier. Thanks in advance
    VY SS
    May 2011
    Auckland
    aaronevolution's Avatar
    aaronevolution is offline Donating Member
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    Quote Originally Posted by SlvrR8 View Post
    It's illegal an stupid. But you could probably install a switch.
    Vx Clubsport R8
    Sep 2011
    Townsville QLD
    I put in blue parkers today but want them to de activate when lows are on
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    VY SS
    Jun 2006
    Albany
    easiest way would be use 2 changeover relays wired behind each headlight, use the lowbeam as your trigger wire then cut the park light wire and connect one end to pin 30 and the other end to pin 87a. is the blue led really that noticeable when your low beams are on?
    Vx Clubsport R8
    Sep 2011
    Townsville QLD
    Thanks for your detailed response. There not reAlly that noticeable i just tested them. I might just roll with it. Thanks for your advice
    VE
    Mar 2011
    n
    Roll with it right up to the defect notice...
    HIDs.....LEDs..... DRLs..... CHEV Badges..... ->
  1. vz parker light wire's?????
    By jasnos in forum Electrical Wiring / Questions
    Last Post: 25-04-2012, 04:58 PM
  2. Parker Light Removal
    By CKaras in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 01-04-2011, 01:45 PM
  3. Parker/H4 Light problem
    By lion_g in forum Electrical Wiring / Questions
    Last Post: 01-07-2009, 03:05 PM
  4. Red L.E.D Stop/Parker Tail light Bulbs
    By r_i_d_a_h in forum Parts And Other Items For Sale
    Last Post: 05-05-2008, 11:23 PM
  5. parker light
    By guyman in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-04-2008, 10:45 PM
