Results 1 to 7 of 7
Thread: vs ute battery keeps going flat
    vs ute
    Feb 2012
    newcastle
    Default vs ute battery keeps going flat
    i have a vs commodore ute and the battery keeps going flat. it is a hard problem to solve because it happens really inconsistently. i have changed the battery, changed the alternator, and it kept going flat every few days, sometimes longer than others. i noticed my tensioner was pretty flogged out so i changed that thinking the belt may be slipping on the alternator, and it was good for about a 6 weeks than this afternoon after driving home from work, it was flat again.
    can somebody please give me a few thoughts???? could the starter motor possibly have anything to do with it???
    Ghost's Avatar
    Ghost is offline Donating Member
    Vr Commodore Executive 1993
    Sep 2011
    Adelong New South Wales
    Have u done a test with a multimeter to make sure your battery is actually charging starter motor is only there for 1 purpose to start the car that's it check to make sure nothing is active after ignition. Off as well
    vs ute
    Feb 2012
    newcastle
    is there a test i can do to see if there is anything active after ignition os off?
    Ghost's Avatar
    Sep 2011
    VR Executive
    Dec 2009
    1st in Elec probs.. Check your Earth straps the (neg) battery Leads to both body and engine.. this one's nailed me twice... heheh
    You say you changed the Alt. New? Reco? err.... wrecker?
    Simplest Alt. test is chk Voltage with voltmeter across Battery poles look for around 13.5-14.5V while engine is running.
    If it's less than 13.2 your Alternator/Regulator are top of suspects list.. good luck.
    Baggus
    VR Executive
    Dec 2009
    Battery Drain when off?
    Are you running a Doof Doof amp?
    Is it powering down properly?
    There's always a small current draw when your ignition is off.
    should be quite small though..
    Radio Memory.. security system. etc.
    Simplest test...
    grab a 5 amp fuse.
    With ignition off doors closed, disconnect battery + and hold one of the fuse's poles on the Battery positive. touch the Battery cable to the other fuse pole and if the fuse heats or blows, you're drawing more than 5 amps .. That's too much..
    or
    Buy El cheapo Dash Ammeter (Needle sits in the middle and tells you which way the juice is flowing..)
    These things have 2 poles.. With ignition off doors closed disconnect battery + and place one of the meter's poles on the Battery positive. touch the Battery cable to the other meter pole and the meter should read less than 1 amp..
    If it's drawing more than 1 amp.. something's still connected that shouldn't be..
    try removing fuse #1 redo test..
    replace fuse 1 remove fuse 2 redo test..
    you get the pattern..
    good luck :-)
    Baggus
    VE
    Mar 2011
    n
    Mate, seriously - if you think this might have anything at all to do with your starter motor, you should see an auto electrician.
    HIDs.....LEDs..... DRLs..... CHEV Badges..... ->
  1. flat battery, how do i get in?
    By 2LOUD2OLD in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-01-2011, 01:57 PM
  2. Flat Battery
    By ciddyau in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-09-2010, 06:39 PM
  3. flat battery
    By Petes VY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-07-2009, 08:54 PM
  4. VQ Battery Going Flat
    By VQ Stato in forum Electrical Wiring / Questions
    Last Post: 11-07-2005, 04:29 PM
  5. Flat Battery
    By Randy18 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2005, 12:38 PM
Tags for this Thread
