Results 1 to 7 of 7
Thread: Dual reverse camera wiring
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Default Dual reverse camera wiring
    I'm putting dual reverse cameras on my van and I'm stuck with the wiring. One thing I'm totally balls at is wiring anything that isn't a speaker! I know that normally reverse cameras switch on when reverse is selected but I want to have them on a manual switch. I plan on picking up power from the cig lighters so I can't accidentally leave them switched on.
    So far I have all my negatives and positives together on the cameras and screen but I'm bloody stumped as to what happens now and where the wires run to the switch. I've added a rough arsed diagram of what I've done.
    I know it's probably a simple fix but my brain just can not compute where I run the wires switch. If someone could finish it off I'd be muchly appreciative. If you need more pics just ask and I'll get them up ASAP.
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    without knowing what the terminals on the switch actually are, i'd say that looks pretty spot on.
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    The switch wasn't labeled which is why I toasted one. I set it up on my work bench with a spare and I think I got it, just needed confirmation. Cheers.
    wamboin23's Avatar
    Apr 2009
    Wamboin, NSW
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    It worked! And I have to admit I'm bloody impressed with myself. I mounted a push button under the dash and it looks neat as! All I need to do now is mount the tailgate camera, it's all wired ready to go, should take me an hour tops.
  1. Reverse Camera in 2010 SV6 Ute
    By jenson in forum ASR Audio & Electronics
    Last Post: 29-04-2011, 02:00 AM
  2. Reverse Camera
    By vz 914 in forum VE Holden Commodore (2006 - ?)
    Last Post: 04-11-2009, 04:06 PM
  3. vt reverse light wiring for camera
    By boogiepete in forum Electrical Wiring / Questions
    Last Post: 04-06-2009, 09:55 PM
  4. VE reverse camera
    By tcooper in forum VE Holden Commodore (2006 - ?)
    Last Post: 15-02-2009, 12:19 PM
  5. Reversing Camera - what camera to get and where to connect my reverse wire?
    By ozzie_online88 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-07-2008, 03:27 PM
