VSEXEC
- Jun 16, 2005
- 156
- 0
- 16
- Age
- 38
- VS EXECUTIVE
Hi guys,
Im building up a track car at the moment and have removed the wiring harness as I want to make up my own so I can run just what I need. Im tossing up whether to keep the ABS as Im running a twin turbo setup and hope to find away around it without removing it. My question is if I build my own loom can i wire up to the ABS or is it controlled by the BCM/ECU. The car will also be using a Haltech computer so I will be turfing the standard computer.
Thanks
Thanks
