vtonp
- Jun 11, 2009
- 27
- 0
- 0
- Location
- melbourne, VIC
- '98 VT commodre
hay guys.
having some trouble with my 2001 VX wagoon ( v6 )
the temp gauge is not working and neither is the low speed fan. it has a brand new temp sensor that we put in last night that hasnt changed anything and also on the dash when you turn ignition on the SERV ERROR comes up indicating a problem with the cluster...... have had it plugged into a scan tool with no real success so we are thinking there is an issue with a dodgy wire somewhere..... what im trying to find out is which directing the infomation travels..... as in does the temp sender send the infomation to the cluster and the BCM reads it from the cluster .... Im thinking that if it travels that way and the wire is damaged between the sender and cluster it would explain why the gauge dosnt work and in return why the BCM dosnt turn the fan on ?
or is it the opposite and the sender goes to the BCM and then onto the cluster ?
any info would be greatful so we know where to start looking
( also we have had test light on the wire to the temp sensor and that seems fine, and all earths and plugs are connected )
thanks in advance
thanks in advance
