Hello.
I've been mucking around for a while collecting the parts I need to fit the stereo buttons from a VS calais/statesman on my VS berlina.
I got all the parts.
switches, remote radio module which I am pretty sure I got the correct box, has 2 tabs on each side for screws that hold it on, was below the bcm and it's a black plastic box, not sure why it has some wattages listed on it like 2x55w etc I thought it was for headlights but i could not find any other module and the wire colours seem to be the same on it like the ones on the gregories wiring diagram.
Anyway i wanted to hook it up on the bench before installing it to the car to see if i could get it to work.
I hooked up the factory calais head unit ground and both power wires to get it to turn on.
From the module.
Black wire - directly to battery ground
Brown wire - to brown wire on the head unit, i take it this is for the signal from the module to head unit.
Yellow wire - To power
Yellow/Black wire off module -- Yellow/black wire coming off steering wheel.... this goes through the horn wiring and to the buttons Yellow wire.
The other wire coming off the wheel was a black wire, I grounded this to battery.
Turned head unit on, but its not respond to anything from the buttons, even tried another set of buttons.
Any ideas? Just want to confirm the module I got is the correct one it has to be, double checked the wiring seems to be right.
Cheers.
From the module.
Cheers.
