Hi
Had an issue with the battery going dead flat last week and requiring an jump start just to get into car!!! The battery was tested and found to be ok but i had already replaced with an new battery. Just now hit the lock on the key fob once and the left blinkler light stayed on!!! reopened the car and locked again and it turned off. Is this an fault code or is somthing happening with the BCM Any ideas THanks
The car is stock and owned for the last 6 years, also can you open the via the drivers door lock if the battery is flat?
