evening ladies and gents,
i have recently done the ''GTO aux hardwire' for my iphone.
its got me thinking...
my plan is to cannibalize an old ipod USB cable and connect the audio outs from that to the headunit replacing the AUX cable and then hardwire the 12v charging cables directly to the power feed to the ciggie lighter.
i have the pin out numbers for the cable but im not sure of the cable colours :S if anyone knows there way around an ipod cable advice would be great
any thoughts or ideas would be much appreciated
cheers
Good luck.. Most if not all formed plugs only have the required pins and resistive switch for the application needed. So giving you the colours is pointless as it's a wired USB lead..
You could always cheat and get yourself a "ipod 3.5mm usb lead" (or simular) and a Cigi Charger USB Adapter ...on flogbay cheap as chips and would save loads of phucking about!
Cheers,
Dave
