Desparately need to know what each of the 18 Pins are for on the back of the standard Eurovox Header in the VT Commodore. Installing new BETTER unit but don't know the existing plug. Please help.
try this, don't know what unit it is for though,
executive & berlina
black/white x2 - earth
orange/black - power + fuse #23
yellow - accessory power + fuse #16
brown/white - illumination from light circuit
grey - illumination from light circuit (check wire same clour as a speaker wire)
yellow/black - mobile phone connection plug
yellow/red - to aerial & c16 on bcm
white - c13 on bcm
light blue - c14 on bcm
grey - lhf speaker
tan - lhf speaker
yellow/blue - lhr speaker
brown/black - lhr speaker
light green - rhf speaker
green - rhf speaker
blue/black - rhr speaker
blue/orange - rhr speaker
calais
violet - b3 on bcm
black/red - to steering wheel clock spring
black yellow - to steering wheel clock spring
sorry not too sure on + and - on speakers or what the wiring to bcm does, but hope it helps. Try supercheap for a wiring conversion harness.
kind regards Guy
120 in a 100 zone.....Sorry officer....I thought you where trying to give my wife back!!!!
I just installed a head unit in my VT (I can make a wiring colour chart if anyone needs it). I went to Autobarn and bought an Aeropro wiring harness to suit a VT, but it turns out that is was the female end (the same as the connector in the car) so it was for installing a VT headunit in another car. It wasn't completly usless though, i used it to see which colour was which on the VT loom, as it came with the IEE standard colour wires on it (and even every wire itself was marked what it was).
So be careful if you buy a harness. Make sure it's the male end (looks the same as the connector on the VT cassette deck).
QUOTE (Prodigee @ Mar 26 2004, 06:17 AM)I just installed a head unit in my VT (I can make a wiring colour chart if anyone needs it). I went to Autobarn and bought an Aeropro wiring harness to suit a VT, but it turns out that is was the female end (the same as the connector in the car) so it was for installing a VT headunit in another car. It wasn't completly usless though, i used it to see which colour was which on the VT loom, as it came with the IEE standard colour wires on it (and even every wire itself was marked what it was).
do u have wiring colors for vr commdore standard eurovox i need to put in cd player??? help!
