Hi Guys.
I wired up a new oil pressure gauge to my VS on the weekend and am having a few small issues.
Heres how I wired it:
Gauge:
+12V Power/12v Gauge Backlight > Spliced into pink ignition wire (the 12v feed I have used for gauges in the past with no issues)
Gauge Ground Wire > Grounded to one of the metal bars near the fuse box under the kick panel
Oil Pressure Sender:
LED Memory (no idea what that does) > + Battery Terminal as directed by gauge instructions
Sensor Ground Wire > Grounded to the chassis
It seems to work ok but whenever I turn the headlights on or turn the indicators on it seems to throw the readings out by around 10-20PSI so it almost seems like its not been grounded correctly :/
The only thing I can think of is that I grounded the oil pressure gauge to the same point as my voltage gauge (which is also getting its 12v power from the pink ignition wire just FYI)
Can anyone tell me what could be wrong?
Thanks
Forever in the garageNew Weekend Cruiser
Shouldn't you have the backlight wired to your light circuit so it comes on witrh the headlights? Maybe that is your issue?
Visit my Facebook page
Nuff said really.
1999 VTII SENATOR
YOU BUY!!!
ALL SERIOUS OFFERS CONSIDERED
http://www.carsales.com.au/private/d...o=Stock&items=[Make:HSV,Model:SENATOR,Series:VT%20II]&sort=default
Yeah as above you shouldnt be wiring the gauge backlit to the ignition wire. Wire it to your headlights or something that dims when you switch your head lights on.
Pick up the power for the backlight from a different source then.
Nuff said really.
1999 VTII SENATOR
YOU BUY!!!
Led memory is so it remembers what color I want it set too.. It needs to have a permanent power.
Wanted to buy VC sunroof
Pm me
also keen to trade electrical work for parts or other car related bits/skills
I would try the guage ground to the chassis or confirm that the metal bar you currently have it connected to, has a 'good' ground.
Illegitimi Non Carborundum
Ok, tried a heap of different places for grounding.... also tried getting my power from various locations with and without illuminations hooked up.
Still same deal.
Think I will go and get some proper speco mechanical gauges....from what I have read I will never get a truely accurate reading with an electronic gauge
Did you disconnect the oil warning light?
Nuff said really.
1999 VTII SENATOR
YOU BUY!!!
Dumb question but did you run the new oil psi sensor correctly into the sump?
I ran electric gauge on the vx and it worked great..
Also in cabin mechanical is defect territory.
Pm me
My light is connected to accessory power so it's easy to see in the daytime. That won't be the problem, gauge doesn't know if the light power is coming from acc, ign, lights, etc.... as long as it's 12 volts.
