Results 1 to 8 of 8
Thread: Aerial goes up, Aerial goes down!!!!
    VR 5.0L Ute, 1961 XK Ford
    Mar 2012
    Reynella, Adelaide
    Default Aerial goes up, Aerial goes down!!!!
    VR 5.0L Ute Aerial Problem
    I have 2 buttons on the centre console just below the radio, one is to raise the Aerial, the other is to lower it, problem is when I raise the aerial and release the button, the Aerial goes down on it's own,
    I am wondering if the Aeriel is buggered or is the "Down" button jammed up somehow???
    Cheers Paul
    Drive it like you stole it!!!
    http://forums.justcommodores.com.au/...-5-0l-ute.html Project Impulse
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged
    Jan 2006
    Springwood NSW
    VY SS
    Jun 2006
    Albany
    sounds normal. if you have an aftermarket unit it will usually extend the aerial when you switch to radio, then you should be able to adjust the aerial up and down. if the unit is on the cd player or something it should lower the aerial, you can push the up button but will automatically retract.
    Mar 2012
    Reynella, Adelaide
    Hey Guy's,
    Yeah, It is an Aftermarket Unit, Pioneer Head Set, Guess the Guy who put it in didn't wire it properly, Gonna have to go thru the wiring, and try locate the proper wire.
    Don't suppose you know what "ILL" means, it's a label on one of the wires, I have labels on the "Battery"," Accessories"," Remote" and the one with "ILL", Assuming the "Earth" Wire is the Black one!!
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    Jan 2005
    ILL is illumination
    you need to hook the "remote" wire to the yellow/red wire in the loom
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Problem is with Pioneer headunits dont have a separate antennatrigger wire, so they only way is to do as hak said..
    Power is measured in DECIBEL
    hakhawk's Avatar
    Jan 2005
    leats his is a semi automatic antenna, he can just wind it down as far as he wants, even with the unit on
    Mar 2012
    Reynella, Adelaide
    Thanks for your help Guy's, But, Looks like I gotta pull the whole thing out and re-wire it, Dunno who put it in (was there when I bought the car) But, there's a million wires going in all directions behind the head unit. Wanna put new speakers in anyway!!
    Thanks again.
    Cheers Paul
  1. How do you replace aerial base on a rear roof mount aerial?
    By steveejay_1 in forum VE Holden Commodore (2006 - 2013)
    Last Post: 07-08-2011, 05:21 PM
  2. vs aerial
    By joshooaahh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2008, 09:14 PM
  3. aerial
    By tug33r in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-09-2007, 06:58 PM
  4. car aerial
    By Mr_Calais in forum Car Audio
    Last Post: 12-02-2007, 09:29 PM
  5. aerial
    By StatOmaN in forum Electrical Wiring / Questions
    Last Post: 12-01-2006, 12:34 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
