Results 1 to 10 of 10
Thread: constant +12v in doors
    03 VY Acclaim
    Dec 2011
    Question constant +12v in doors
    Anyone know of any? Just had a quick probe and couldn't seem to find any
    Ghost's Avatar
    Ghost is offline Donating Member
    Vy Commodore Executive Wagon 2002
    Sep 2011
    Adelong New South Wales
    Nope but unless its something that's light on battery power it will be a waste of time you will always have a flat battery
    Sent From My Galaxy S2 Using Tapatalk 2
    03 VY Acclaim
    Dec 2011
    Led strip, have a switch for the neg, or is there any that provide power when the door is open, really don't wanna have to run wires from the interior light
    Ghost's Avatar
    Sep 2011
    You could put the leds in the foot wells and wire it under the dash and try tapping into the door switch I'm not to sure though alternatively if there is a light near your ignition tap into that wire that way the lights will turn on once the car is unlocked and will turn back off once the cars started I'm thinking about it now lol
    03 VY Acclaim
    Dec 2011
    Well I planned on having the strips under the door and to have them turn on individually ie like door lights on Calais etc as I already have another set of door switches :-) but looks like I'll have to take power from the interior light :-\
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    you should be able to source the power feed to the interior light from under the dash, then just T off to each of your doors. Its fun feeding the wires through the rubber grommit and in to the tubes to ur doors. old wire coathanger and racing tape does wonders!
    03 VY Acclaim
    Dec 2011
    Ahah and don't I know it, I've run speaker wire through the fronts :-\ , but whereabouts on the dash, because I was just going to try find it from the b pillar
    Jonno's Avatar
    Jonno is offline :)
    Nov 2010
    Vic,
    electric mirrors one for when the ignition is on.. when its off.. interior light switch?
    Quote Originally Posted by Rufys View Post
    yup! I think I might actually be gay
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged
    Jan 2006
    Springwood NSW
    Calais have the 'puddle lights' in the door trim already, so unless there is a free plug lying around you will have to run new wiriing into the door, which is what Phreddy on here had to do when he installed Calais door lights into a friends car, as there would be no other constant +ve source.
    Power is measured in DECIBEL
    03 VY Acclaim
    Dec 2011
    Quote Originally Posted by SweetWagon View Post
    thats pretty much how i want them to work, ill probably have to go from the b pillar loom for drivers side and maybe from the acyualy light for passengers. how do i access the rear door gromet had a look today, and its really low, is it just behind the door sill?
  1. Constant wiring?
    By Hibbo_Jnr in forum Car Audio
    Last Post: 04-09-2011, 01:21 AM
  2. What Other Colours Can be The Constant? 03 VY SS
    By Simsy23 in forum Car Audio
    Last Post: 18-08-2011, 05:21 PM
  3. LH indicator a 'constant' on
    By emmtee83 in forum Electrical Wiring / Questions
    Last Post: 03-12-2009, 09:55 AM
  4. FS [VIC]: VS stato rear doors w/ door trims, VS 'S' Ute complete doors and VS Seats
    By georgeonboost in forum Parts And Other Items For Sale
    Last Post: 28-08-2008, 06:04 PM
  5. VR needs constant revival :(
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2006, 11:34 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
