za289w
G'day all, I have just put a 304 into a GU Patrol, It cranks over nicely, has strong spark, will fire off aerostart has power to coil, module, injectors & ecu while cranking, ECU has good earths, hall effect putting out good signal etc etc but for some reason the ECU will not pulse (earth) the injectors so she wont run! Im not 100% sure what the motor is from originally I am told it was VP but the guy I brought it from had it in a VC so the loom had already been modified. How do I tell for sure what loom & ECU I have, and also can anybody help me diagnose why it wont pulse the injectors! Thanks in Advance.
PS yes I have trolled through these and many other forums looking for an answer.....
