Drew..
Firstly, a very comprehensive explanation, detailed and easy to understand. Well done, if people bothered to explain things well more often, a lot of threads would be a lot more useful.
I do however have some questions, perhaps you have mistyped, got mixed up or something or I just dont understand. I dont make any claims of expertise here, and you may be completely correct, but perhaps you could clarify for me.. this is in no way an attack, you sound very informed, but its a bit different to the way I understand it and I do like to learn..
Quick lesson in electrical theory:
The alternator cannot force more current through the system than what it draws/requires, so no it wont hurt the existing harness, as the car wont now be pulling more current before, just because more is available now doesn't mean the car will pull it unless you've added in a stereo system and thermo fans which increases the cars electrical needs beyond the original design.
Makes sense to me.
Therefore if you want to provide more current to the car, i'd be adding in a 2nd or extra cable from the alternator to the battery and leave the original cable as is.
The battery's first job is to start the car, it's 2nd job is to soak up any excess current from the alternator, so the 2nd cable is mean't exactly for that.
How can you provide extra current to the car if it cant use more than it needs? The batterys purpose, of course to start the car, and to provide storage for power. Of course, the amount of storage it provides depends on the battery, but all it does is store power.
I dont actually see the point in the second cable, a single heavier cable would be neater but not provide the probably unnecessary backup, thats all. A single heavier cable will also provide less resistance, giving a net gain over two smaller cables.
Reasoning behind this is: if you have installed a decent stereo system, the amplifiers main power feed cable is connected directly to the battery, so the extra load on the car's electrical system begins at the battery so the extra juice from the bigger alternator needs to go directly to the battery before being sent to the rest of the car anyway.
As I understand it, it needs to go to the battery, but it doesnt need to go through it. The battery post is effectively a connector, via which you connect all of your power cables to your alternator, and to which the battery is also connected.
As you have mentioned further down, electricity follows the path of least resistance, and this does not include detours through the battery. The current will travel down the alternator cable, and if a demand exists further down the line, it will continue via the connections at the battery to where it is required, not into the battery and then back out.
Obviously the battery, being the path of least resistance, will get first priority, but once it is fully charged it is not drawing any current at all, therefore the current continues to somewhere else.
If you've got thermo fans etc the relay power feed should be connected as close to the battery anyways (to feed it from under the dash defeats the purpose of using relays to get better power feed to new/extra circuits in the first place)
When a high current load device in the car's system starts up/turns on, the alternator's regulator allows more current to flow.
When that device switches off (say thermo fan for example) the extra juice coming out of the alternator now has nowhere to goto except to the battery to be soaked up.
Isnt that contradictory? 'When the load increases, the regulator allows more current to flow'
'When the load decreases, the extra juice has nowhere to go but to the battery to be soaked up'
Doesnt the regulator then reduce the extra juice if this is the case? And just how much excess power can the battery soak up.. what happens when the power has nowhere left to go and the battery can soak up no more?
I think the basic problem with most of this post is 'the regulator allows more current to flow'. I believe this to be incorrect as I explain below.
This is why in fuel injected cars with ecu's... they can get fried if you run the car and disconnect the battery while the engine is running. As soon as a high draw device turns off... the current forces it's way back to common/earth wherever it can, usually burning stuff out along the way.
Again, isnt that what the regulator is for in your explanation? Remember I am not the one with knowledge here, I am simply hoping you can clarify. I'm having difficulty understanding what the regulator has to do with current draw at all.
I always thought a voltage regulator regulated volts, not amps. Amps are simply how much current is being drawn, and current draw is controlled directly by demand, and available total current obviously is controlled by the output abilities of the alternator.
The original cable splits near the battery, one direction goes into feed the rest of the car the other goes to the battery via a fuseable link.
Electricity follows the easiest path exactly like water does, so if you hook a 2nd cable 8 or 4 gauge from the alternator to the battery, the charge from the alternator will as above follow the easiest path which will be the new cable to the battery, the car then will pull that charge like normal from the old wire via the battery ignoring the section coming from the alternator.
Leave the original cable in place for 2 reasons: 1 to share a load balance of current and 2 if in the event of a wiring issue, at least you have a backup source from the alternator.
I usually have 2 fuses on the 2nd extra/new/upgraded cable from the alternator. 1 close to the alternator end and the other near the battery. You dont want to have a short on a 8 or 4 gauge cable and end up with unwanted "arc welding"
If you leave the original cable in place, or upgrade it, or add a second one, if it goes to the battery it will not ignore anything? It will simply provide power via the shortest available route as required, again, not detouring through the battery. The redundant cable may be useful one day I guess, but how often do you burn out an alternator cable anyway?
Is the alternator a aftermarked 1 wire replacement or a VN-VS (not series 3 vs...) 5.0L alternator?
If it's a VN type, lookup the bosch website for info on it... it's not much better than a 55amp VK alternator as the VN one is only 14 amps at idle but ramps up to 85 amps above 1200rpm.
VS series 3 and VT series 1 (vt 5.0L) are 60 amps idle and 120 amps above 1200 rpm.
So if you're looking to solve a lack of power when idleing for extended periods with alot of load, the vn alternator isn't much good if you're stuck at the lights for a long time at night with headlights on, big stereo running and having ac/fans and thermo's running.
This makes sense if the numbers are correct.
