s1mon
Hi All
As the title suggests I am trying to get a VN V6 to run, I want to make sure it runs before I put it in to a rockcrawler project.
This is what I tried today
I have wired C16 and B1 to +ve 12v on the battery (orange/black wire on the 6 pin plug)
I have wired the injectors to +ve 12v on the battery (orange/red wire on the 6 pin plug)
I have wired a relay to control the fuel pump which seems to cut in and out with the ignition
I have the fuel pump going into a jerry can and the fuel return going in the jerry can, there is fuel coming out of the fuel return when the engine is cranking so I would assume there is fuel pressure in the injector rail
I have +ve 12 going to the pink wire on the 10 pin plug for the ignition
The problem I am having is there is no fuel coming through the injectors, so the engine cranks but won't fire, there is spark, and when I spray aerostart in the throttle body it fires.
Just wondering if I have missed something obvious or any ideas as to why its not starting
Simon
Simon
